Allow another schema than « public » for Langchain SQL Agent with PostgreSQL
The idea is:
Add the ability in AI node for SQL Agent to allow for another schema than “public” for postgreSQL. The feature list-tables-sql returns only public tables. Langchain standard feature enables to select another schema.
Can you please add this feature ?
My use case:
Interact with LLM and sql DB where the data is not stored in “public” schema.
One often does not use the public schema by default
Just a schéma argument in Langchain
No
You can simply define the schema name followed by the default table name that n8n creates to save chat histories.
Like in this example:
