Allow expression for JSON Schema in Structured Output Parser node
The idea is:
Structured Output Parser node doesn’t allow expression. It has to be fixed value which is surprising as everything else can be variables.
My use case:
I am working on a n8n workflow that takes as input a system and user prompt and outputs the results from llm completion. I wanted to add structured responses available. For that I wanted my users to pass their JSON schema as input for me to use it in the node.
It is beneficial for everyone who doesn’t want to duplicate workflows just because we define a different JSON Schema in output Parser.
I am not sure to have the knowledge to do so. I am only working with Python.
Couldn’t agree more!
I updated for the latest version yesterday and suddenly my most powerful and valuable workflows started crashing!
Please guys, could you rollback and make possible to write expressions on the Structured Output Parser node?
Same problem here
+1
It’s baffling that this particular node doesn’t allow expressions. Everything in my workflows is parameterized and even driven by content. This one particular node breaks this powerful pattern.
I’m also willing to help out making this happen, e.g. by reviewing or contributing code changes as far as my nodeJS/javascript knowledge allows.
+1
I just have the same issue right now. I want to create universal tool with dynamic schema.
+1
New to n8n, very impressed with the platform - this missing ability very quickly surfaced as way out of order for the platform, and potentially critically important - as others have correctly noted.
Wonder if there is a deeper tech reason behind or they just forgot to flip the switch on the fields
I’m having the same problem. Having the ability to write an expression in the JSON schema of the Output Parse would solve a lot of headaches. It seems an easy implementation, too.
Same here, I need to be able to pass values dynamically.
Is there any news on this, or does anybody have any workarounds?
+1 This would be a game changer for my workflow
+1 having the same problem here
+1 Ran into this issue 2 hours into using n8n. The rest of the platform looks super useful but I need this functionality for most of my work :frowning:
+1 please this is critical and no reason for only that to not allow expression
Absolutely useful, just upvoted! I had a whole thread prepared thinking I was the only one until I saw this :sweat_smile: :joy:
i just built a custom node that handles this.
GitHub - volkovmqx/n8n-nodes-advanced-output-parser please test it out and create issues in github if there is problems. Note: this is not production ready, use at your own risk.
Hi everyone, support for expressions in JSON schema parameter was just merged this week. So it should go out on Monday in v1.101.0
I’ve created a JS code that can be attached to the pipeline that will convert a sample JSON into a JSON Schema that can be referenced in the Structured Output Parser.
The base code comes from the N8N structured parser generator itself
I understand expression is allowed for Define Using JSON Schema.
Is it not allowed for Generate from JSON Example?
