Asana Node - Add Task to Project [GOT CREATED]
I might be missing something, but would it be easy enough to add the ability to specify a project to which a Task should be added? At the moment it seems there isn’t a way? Thanks!
@Markt got created. Also added the resource Task Project where you can add and remove task to/from a project.
We will let you know when is released.
Wow, that was fast! Thanks so much!
Got released with n8n@0.105.0
