Authorization Issue with Wordpress Node
Hello Community,
I’m encountering an authorization issue with the WordPress node in my n8n workflow when attempting to perform operations that involve creating or modifying content (e.g., creating posts, updating users). Despite ensuring that my authentication token has administrator-level permissions , I consistently encounter “Unauthorized” errors.
while actions like getting users or pages is working just fine!
  • **Running n8n via :cloud
Hi @Malak Welcome to the n8n community! :tada:
Do you mind updating the n8n version you’re using along with any screenshots showing the error you’re facing?
Thank you.
here is the version : 1.42.1
and for the error , it shows this
on my Wordpress , this user is an admin
for getting data from the website , it works well
Alright, I see the problem here.
Instead of using your WordPress account password. Create an Application Password.
This can be done easily
  1. Go to Profile in the WP Dashboard
  2. Give a name
  3. Click on “Add New Application Password”
  4. Use that generated password inside n8n
I just tested it myself and it works.
Thank you so muuuuch , It finally works
Awesome. Glad it works :100:
I don’t know what happened but it is not working anymore
but it is only when I add the status: publish
for draft creation it works
I didn’t had this problem before activating a theme called newsy
