Automated Test Stuck for Community Node Submission
Hello,
I recently submitted a community node for review. The automated test, which is expected to take 2-3 minutes, has been running for approximately 4 hours and appears to be stuck.
it says:
Thank you for your submission
We are now performing a set of automated checks on your node. This will take around 2-3 minutes. You can stay here and refresh this page to view the results in a bit, but you will also receive an email once these checks have completed.
Could someone please look into this or advise on the next steps?
Thank you for your assistance.
This is likely a temporary issue with the automated testing system. The n8n team usually monitors these submissions, but sometimes delays happen.
For next steps:
1. Wait a few more hours in case it’s just backlogged
2. If still stuck after 24 hours, post in the #community-nodes channel on the n8n Discord (n8n) with your submission details
3. You could also try resubmitting if the issue persists
The team will eventually get to it, but the Discord channel is the fastest way to get attention for stuck submissions. Hope that helps!
