Beginner course - incorrect unique_id in http request node
I’m just working through the beginner course and the HTTP Request node consistently gives me this error:
I’ve deleted and reconfigured the node several times and continue to get the same error, leading me to believe that somehow I actually have the wrong unique_id. Thoughts? Thanks.
May be related to this, although the error message is not exactly the same:
My solution was to change “Specify Headers“ from “Usig Fields Below“ to “Using JSON“ and provide unique_id as JSON. Double check that your unique_id is the one that you got in the registration email for the level 1 course.
Thanks Markup - all good.
