Hello! I have seen that there is a direct extractor of leads from META: Facebook Lead Ads Trigger, but there is also Graph API, which I think can also extract leads
From what Im getting from online tutorials, this Facebook Lead Ads Trigger happens to pull leads from meta, but its credentials expire every 2 months. Which is not really optimal.
Is graph API better? Have you guys used it successfully to pull leads? I am also not clear which credentials and node I should use to pull leads using Graph API.
Hey @Cristian_Martanov To give you more specific guidance, it would help to know if:
- You need new leads instantly, or is checking for them once an hour/day acceptable?
- How comfortable are you with the technical setup in the Facebook/Meta Developer portal?
The answer to these questions will point you more clearly toward the most suitable method.
I would like to get them instantly or in the 1st 5 minutes or so to message them efficiently.
I would say I’m an informed begginer. I have built an app, and im using whatsapp api as we speak. I created credentials and activated Graph API but Im not sure what the best way to get the leads from META is. I want to integrate leads so that I can make the whole process as efficient as possible.
Hello zenith! I was wondering if you had the time to look over my response? I kinda need to deliver this and any help is highly appreciated!
Hey @Cristian_Martanov sorry for the late response.
Based on your reply, using the official Facebook Lead Ads Trigger node with a webhook will be the correct and most efficient method for your n8n workflow. The setup delivers leads in seconds, meeting your requirement for immediate follow up.
The process involves linking n8n to Facebook’s platform and connecting your WhatsApp API to create an automated lead response system.
Hope this helps
