Doing my own workflow I faced a problem with accessing output data from nodes preceding the node which doesn’t provide output data.
In my case, no output occurs in MongoDB find node when the searched document doesn’t exist yet. In such case, I want to continue processing (set “Always Output Data” in node settings) and then I want to use some data preceding the MongoDB node, but unfortunately the error occurs:
Missing pairedItem data (node ‘MongoDB’ probably didn’t supply it)
ExpressionError: Can’t get data for expression
at createExpressionError (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/WorkflowDataProxy.js:453:20)
at getPairedItem (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/WorkflowDataProxy.js:506:27)
at pairedItemMethod (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/WorkflowDataProxy.js:714:40)
at Object.get (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/WorkflowDataProxy.js:717:40)
at Proxy.eval (eval at _create (/usr/local/lib/node_modules/n8n/node_modules/@n8n_io/riot-tmpl/dist/tmpl.js:377:14), <anonymous>:3:62)
at Object._tmpl (/usr/local/lib/node_modules/n8n/node_modules/@n8n_io/riot-tmpl/dist/tmpl.js:335:60)
at Expression.renderExpression (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Expression.js:205:25)
at Expression.resolveSimpleParameterValue (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Expression.js:184:34)
at resolveParameterValue (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Expression.js:270:25)
at Expression.getParameterValue (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Expression.js:287:31)
at resolveParameterValue (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Expression.js:268:29)
at /usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Expression.js:276:61
at Array.map (<anonymous>)
at Expression.getParameterValue (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Expression.js:276:47)
at getNodeParameter (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/NodeExecuteFunctions.js:1227:42)
at Object.getNodeParameter (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/NodeExecuteFunctions.js:1448:24)
at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Set/Set.node.js:173:18)
at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:652:51)
at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:596:68
at processTicksAndRejections (node:internal/process/task_queues:96:5)
Example workflow
Here are the synthetic workflow which transparently represents the problem:
Last node issues:
- Can’t get data for expression (To fetch the data from other nodes that this expression needs, more information is needed from the node ‘MongoDB’ More info)
- Execution Error.
n8n setup
- n8n version: 0.230.3
- Database: SQLite
- n8n EXECUTIONS_PROCESS setting: own, main
- Running n8n via: Docker
- Operating system: MacOS
