Chat not could not connect to ai agent node
I am using a self-hosted n8n instance with version 1.91.3. I cannot connect the Chat node to the AI Agent node, and the AI Agent node does not look like what is shown in the tutorial.
no message
“nodes”: [
“parameters”: {
“options”: {}
“type”: “@n8n/n8n-nodes-langchain.chatTrigger”,
“typeVersion”: 1.1,
“position”: [
0,
0
“id”: “2e588b2b-e44f-48c5-be33-b2cec875db50”,
“name”: “When chat message received”,
“webhookId”: “df176a5a-a798-45b8-a2b7-17730e261c5d”
“connections”: {
“When chat message received”: {
“main”: [
“pinData”: {},
“meta”: {
“instanceId”: “6a2273868aafb37dd639ac7e446cad25c48e69f9c94440a318487d4f19c3e2eb”
“nodes”: [
“parameters”: {
“options”: {}
“type”: “@n8n/n8n-nodes-langchain.agent”,
“typeVersion”: 1.9,
“position”: [
220,
0
“id”: “88521ee7-a7cd-44aa-aa34-2174d6a1cfd4”,
“name”: “AI Agent”
“connections”: {},
“pinData”: {},
“meta”: {
  • n8n version: 1.91.3
  • Database (default: SQLite): pg
  • Operating system: amazon-linux x86-64
Did you copy this from anywhere?
Sometimes when importing it references the wrong nodes I’ve noticed especially on newer version.
I pasted in, and got this:
So, seems more issue in env
There seems to be an issue initialising the node properly, so it could need a restart? Do you have any community nodes installed also?
I copy from tutorial doc, and I’ve restarted it several times. I’m using docker-compose here and haven’t install any community nodes yet.
services:
  n8n:
    restart: always
    image: n8nio/n8n:1.91.3
    ports:
      - "5678:5678"
    environment:
      - N8N_BASIC_AUTH_ACTIVE=true
      - N8N_BASIC_AUTH_USER=admin
      - N8N_BASIC_AUTH_PASSWORD=securepassword
      - N8N_HOST=your.url
      - N8N_PROTOCOL=https
      - WEBHOOK_TUNNEL_URL=https://your.url
      - WEBHOOK_URL=https://your.url
      - N8N_EXTERNAL_URL=https://your.url
      - DB_TYPE=postgresdb
      - DB_POSTGRESDB_HOST=postgres  # Name of the PostgreSQL service in Docker Compose
      - DB_POSTGRESDB_DATABASE=n8n
      - DB_POSTGRESDB_USER=n8n
      - DB_POSTGRESDB_PASSWORD=securepassword
      - EXECUTIONS_MODE=regular
      - NODE_FUNCTION_ALLOW_EXTERNAL=nodemailer
      - N8N_PUSH_BACKEND=websocket
      - N8N_PAYLOAD_SIZE_MAX=268435456
      - N8N_ENCRYPTION_KEY=rHrdmVuJuhUeA7JDKtkoqQfRZ9wd58lGPmz28JIHu1k=
    depends_on:
      - postgres  # Ensures PostgreSQL starts before n8n
    volumes:
      - ./.n8n:/root/.n8n
  postgres:
    restart: always
    image: postgres:latest
    environment:
      - POSTGRES_DB=n8n
      - POSTGRES_USER=n8n
      - POSTGRES_PASSWORD=securepassword
    volumes:
      - ./pgdata:/var/lib/postgresql/data
Thx, my problem was solved.
I was using Caddy as a reverse proxy, and I accidentally added some Content-Security-Policy configs which I was not quite understand :joy:
After I removed those and restarted the instance.
It worked like a charm.
