Problem in node ‘AI Agent‘
Found similar issues, but none of the answers fixed mine
Tried to use an AI Agent, got a prompt as an input and this is my error:
" Problem in node ‘AI Agent‘
Error Cannot POST /api/chat
Output:
Error
Version: 1.79.3 self host via docker on mac silicon latest version
Could you download your workflow and paste it inside a preformatted text box: </>
How to share workwlow
Pasting your n8n workflow
<your workflow>
Check weather the Ollama is running properly and weather you pulled the image, try chatting once inside the ollama itself, then try to call it via API
