Code Build node
I’ve created a pretty cool and powerful node called Code Build.
This single node when setup will create a Github repo (public or private) and then setup Claude Code (for now) and run a user-configurable prompt using Github actions so that it can build an app in the cloud and then automatically merge into the main branch of the newly created repo when completed.
This allows you to use N8N to programmatically generate apps or websites using Claude Code & Github :exploding_head:
You can find it at GitHub - JoshuaRileyDev/n8n-nodes-code-build: n8n community node for AI-powered code building with Claude Code
Or install via NPM: n8n-nodes-code-build :grin:
