Code Node Hangs When OFFLOAD_MANUAL_EXECUTIONS_TO_WORKERS: "true"
I cannot run the Code node.
Here is my configuration and architecture: When I set OFFLOAD_MANUAL_EXECUTIONS_TO_WORKERS: “false”, the Code node works normally. However, when I set OFFLOAD_MANUAL_EXECUTIONS_TO_WORKERS: “true”, the workflow runs fine without a Code node. As soon as a Code node is present, the workflow hangs (spinning/loading indefinitely) at that node.
Please help me identify what might be wrong with my configuration.
# N8N PRODUCTION STACK
# Queue Mode + External Task Runners
# PHẦN 1: TEMPLATES & ANCHORS (Data Driven)
x-common: &common-config
  restart: unless-stopped
  networks:
    - n8n_internal
x-security: &security-standard
  security_opt:
    - no-new-privileges:true
  cap_drop:
    - ALL
x-logging: &logging-standard
  driver: json-file
  options:
    max-size: "10m"
    max-file: "3"
x-logging-extended: &logging-extended
  driver: json-file
  options:
    max-size: "50m"
    max-file: "5"
# Templates tài nguyên theo cấp độ
x-resources-tiny: &resources-tiny
  limits:
    cpus: "0.3"
    memory: 128M
  reservations:
    cpus: "0.05"
    memory: 32M
x-resources-micro: &resources-micro
  limits:
    cpus: "0.6"
    memory: 384M
  reservations:
    cpus: "0.15"
    memory: 96M
x-resources-minimal: &resources-minimal
  limits:
    cpus: "0.5"
    memory: 256M
  reservations:
    cpus: "0.1"
    memory: 64M
x-resources-small: &resources-small
  limits:
    cpus: "1"
    memory: 512M
  reservations:
    cpus: "0.25"
    memory: 128M
x-resources-medium: &resources-medium
  limits:
    cpus: "2"
    memory: 2G
  reservations:
    cpus: "0.5"
    memory: 512M
x-resources-large: &resources-large
  limits:
    cpus: "4"
    memory: 4G
  reservations:
    cpus: "1"
    memory: 1G
# Template biến môi trường n8n cơ bản
x-n8n-base-env: &n8n-base-env
  NODE_ENV: production
  GENERIC_TIMEZONE: ${GENERIC_TIMEZONE:-Asia/Ho_Chi_Minh}
  N8N_ENCRYPTION_KEY: ${N8N_ENCRYPTION_KEY}
  N8N_TRUST_PROXY: "true"
  N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS: "true"
  N8N_BLOCK_ENV_ACCESS_IN_NODE: "true"
  N8N_GIT_NODE_DISABLE_BARE_REPOS: "true"
# Template database config
x-db-config: &db-config
  DB_TYPE: postgresdb
  DB_POSTGRESDB_HOST: postgres
  DB_POSTGRESDB_DATABASE: ${POSTGRES_N8N_DB}
  DB_POSTGRESDB_USER: ${POSTGRES_N8N_USER}
  DB_POSTGRESDB_PASSWORD: ${POSTGRES_N8N_PASSWORD}
# Template queue config
x-queue-config: &queue-config
  EXECUTIONS_MODE: queue
  QUEUE_BULL_REDIS_HOST: redis
  QUEUE_BULL_REDIS_PASSWORD: ${REDIS_PASSWORD}
# Template runners config
x-runners-config: &runners-config
  N8N_RUNNERS_ENABLED: "true"
  N8N_RUNNERS_MODE: external
  N8N_RUNNERS_AUTH_TOKEN: ${N8N_RUNNERS_AUTH_TOKEN}
# Template PostgreSQL tuning (VPS nhỏ)
x-postgres-tuning: &postgres-tuning
  POSTGRES_MAX_CONNECTIONS: "50"
  POSTGRES_SHARED_BUFFERS: "256MB"
  POSTGRES_EFFECTIVE_CACHE_SIZE: "256MB"
  POSTGRES_MAINTENANCE_WORK_MEM: "32MB"
  POSTGRES_WORK_MEM: "2MB"
  POSTGRES_WAL_BUFFERS: "4MB"
# Template N8N performance tuning
x-n8n-performance: &n8n-performance
  N8N_CONCURRENCY_PRODUCTION_LIMIT: "5"
  N8N_CACHE_ENABLED: "true"
  N8N_CACHE_MAX_SIZE: "10"
  EXECUTIONS_DATA_SAVE_ON_ERROR: "all"
  EXECUTIONS_DATA_SAVE_ON_SUCCESS: "none"
  EXECUTIONS_DATA_SAVE_ON_PROGRESS: "false"
  EXECUTIONS_DATA_SAVE_MANUAL_EXECUTIONS: "false"
  EXECUTIONS_DATA_PRUNE: "true"
  EXECUTIONS_DATA_MAX_AGE: "1080"
  EXECUTIONS_DATA_PRUNE_MAX_COUNT: "50000"
# Template volume n8n
x-n8n-volumes: &n8n-volumes
  - n8n_data:/home/node/.n8n
  - ${LOCAL_DATA_FOLDER}/data/share:/data/share
# Template healthcheck intervals
x-healthcheck-standard: &healthcheck-standard
  interval: 60s
  timeout: 10s
  retries: 3
x-healthcheck-fast: &healthcheck-fast
  interval: 30s
  timeout: 10s
  retries: 3
# PHẦN 2: SERVICES
services:
  # DATA LAYER
  postgres:
    <<: [*common-config, *security-standard]
    image: postgres:17-alpine
    container_name: ${COMPOSE_PROJECT_NAME:-n8n}_postgres
    cap_add:
      - CHOWN
      - DAC_OVERRIDE
      - SETGID
      - SETUID
    deploy:
      resources: *resources-small
    volumes:
      - postgres_data:/var/lib/postgresql/data
      - ./scripts/database:/docker-entrypoint-initdb.d:ro
    environment:
      <<: *postgres-tuning
      POSTGRES_DB: ${POSTGRES_DB}
      POSTGRES_USER: ${POSTGRES_USER}
      POSTGRES_PASSWORD: ${POSTGRES_PASSWORD}
      POSTGRES_N8N_DB: ${POSTGRES_N8N_DB}
      POSTGRES_N8N_USER: ${POSTGRES_N8N_USER}
      POSTGRES_N8N_PASSWORD: ${POSTGRES_N8N_PASSWORD}
      POSTGRES_DATA_DB: ${POSTGRES_DATA_DB:-n8n_data}
      POSTGRES_DATA_USER: ${POSTGRES_DATA_USER:-data_user}
      POSTGRES_DATA_PASSWORD: ${POSTGRES_DATA_PASSWORD}
      POSTGRES_INITDB_ARGS: "-E UTF8 --lc-collate=C --lc-ctype=C"
    healthcheck:
      <<: *healthcheck-fast
      test: ["CMD-SHELL", "pg_isready -U ${POSTGRES_USER} -d ${POSTGRES_DB}"]
      start_period: 30s
    logging: *logging-standard
  redis:
    image: redis:7-alpine
    container_name: ${COMPOSE_PROJECT_NAME:-n8n}_redis
    cap_add:
      - SETGID
      - SETUID
    deploy:
      resources: *resources-tiny
    volumes:
      - redis_data:/data
    command: >
      redis-server
      --requirepass ${REDIS_PASSWORD}
      --maxmemory 100mb
      --maxmemory-policy allkeys-lru
      --save 900 1
      --save 300 10
    healthcheck:
      test: ["CMD", "redis-cli", "-a", "${REDIS_PASSWORD}", "ping"]
      start_period: 10s
  # N8N LAYER
  n8n:
    image: docker.n8n.io/n8nio/n8n:latest
    container_name: ${COMPOSE_PROJECT_NAME:-n8n}_main
    depends_on:
      postgres:
        condition: service_healthy
      redis:
    user: "1000:1000"
    deploy:
      resources: *resources-micro
    volumes: *n8n-volumes
    environment:
          *n8n-base-env,
          *db-config,
          *queue-config,
          *runners-config,
          *n8n-performance,
      # Cấu hình riêng cho main instance
      N8N_HOST: ${N8N_SUBDOMAIN}.${N8N_DOMAIN_NAME}
      N8N_PORT: 5678
      N8N_PROTOCOL: https
      WEBHOOK_URL: https://${N8N_SUBDOMAIN}.${N8N_DOMAIN_NAME}
      # Vai trò: Broker cho task runners
      N8N_RUNNERS_BROKER_LISTEN_ADDRESS: 0.0.0.0
      OFFLOAD_MANUAL_EXECUTIONS_TO_WORKERS: "false"
    healthcheck:
      <<: *healthcheck-standard
      test:
          "CMD-SHELL",
          "wget --no-verbose --tries=1 --spider http://localhost:5678/healthz || exit 1",
      start_period: 60s
    logging: *logging-extended
  n8n-worker:
    container_name: ${COMPOSE_PROJECT_NAME:-n8n}_worker
    command: worker
    depends_on:
      postgres:
      redis:
      n8n:
    user: "1000:1000"
    deploy:
      replicas: 1
    environment:
          *n8n-base-env,
          *db-config,
          *queue-config,
          *runners-config,
          *n8n-performance,
      # Vai trò: Requester - kết nối đến broker
      N8N_RUNNERS_TASK_BROKER_URI: http://n8n:5679
  n8n-runners:
    image: n8nio/runners:latest # Image đặc thù
    container_name: ${COMPOSE_PROJECT_NAME:-n8n}_runners
    depends_on:
      n8n:
    user: "1000:1000"
    deploy:
    environment:
      NODE_FUNCTION_ALLOW_EXTERNAL: ${NODE_FUNCTION_ALLOW_EXTERNAL:-*}
      # Kết nối đến broker
      N8N_LOG_LEVEL: ${N8N_LOG_LEVEL:-info}
  # PROXY & TUNNEL LAYER
  caddy:
    <<: *common-config
    image: caddy:2-alpine
    container_name: ${COMPOSE_PROJECT_NAME:-n8n}_caddy
    security_opt:
    cap_add:
      - NET_BIND_SERVICE
    cap_drop:
      - ALL
    deploy:
    volumes:
      - caddy_data:/data
      - caddy_config:/config
      - caddy_logs:/data/logs
      - ./Caddyfile:/etc/caddy/Caddyfile:ro
    healthcheck:
      test:
          "CMD",
          "wget",
          "--no-verbose",
          "--tries=1",
          "--spider",
          "http://localhost/health",
      start_period: 10s
    labels:
      com.${COMPOSE_PROJECT_NAME:-n8n}.service: "caddy"
  cloudflared:
    image: cloudflare/cloudflared:latest
    container_name: ${COMPOSE_PROJECT_NAME:-n8n}_cloudflared
    depends_on:
      caddy:
    deploy:
    command: tunnel --no-autoupdate run --token ${TUNNEL_TOKEN}
    healthcheck:
      test: ["CMD", "cloudflared", "tunnel", "info", "--log-level", "error"]
      start_period: 30s
    labels:
      com.${COMPOSE_PROJECT_NAME:-n8n}.service: "cloudflared"
  # BACKUP LAYER
  backup:
    <<: *common-config
    image: prodrigestivill/postgres-backup-local:17-alpine
    container_name: ${COMPOSE_PROJECT_NAME:-n8n}_backup
    profiles:
      - backup
    depends_on:
      postgres:
    volumes:
      - ./backups:/backups
    environment:
      POSTGRES_HOST: postgres
      POSTGRES_DB: ${POSTGRES_N8N_DB}
      POSTGRES_USER: ${POSTGRES_N8N_USER}
      POSTGRES_PASSWORD: ${POSTGRES_N8N_PASSWORD}
      POSTGRES_EXTRA_OPTS: "-Z6 --schema=public --blobs"
      SCHEDULE: "@daily"
      BACKUP_KEEP_DAYS: "7"
      BACKUP_KEEP_WEEKS: "4"
      BACKUP_KEEP_MONTHS: "6"
      HEALTHCHECK_PORT: "8080"
    healthcheck:
      test: ["CMD", "wget", "--spider", "http://localhost:8080"]
      start_period: 30s
    labels:
      com.${COMPOSE_PROJECT_NAME:-n8n}.service: "backup"
# PHẦN 3: VOLUMES & NETWORKS
volumes:
  postgres_data:
    driver: local
  redis_data:
    driver: local
  n8n_data:
    driver: local
  caddy_data:
    driver: local
  caddy_config:
    driver: local
  caddy_logs:
    driver: local
networks:
  n8n_internal:
    driver: bridge
Welcome to the n8n community mr.quangdt!
We’ve experienced the same problem on our self hosted instance and indeed others have reported a similar issue before: Code node hanging in n8n cloud
In my case the only thing that helps is to restart the instance. My assumption is that some workflow crashes the worker and when it restarts it doesn’t properly register itself again.
I can only hope this behavior gets fixed soon by the n8n team as this is quite disruptive and annoying.
