Code Node Not Executing After Sheet Node in n8n
Hello n8n Community,
I am facing an issue where my Code node is not executing after a Sheet node, even though the Sheet node is working fine and returning data. The flow was working properly before, but now the Code node does not run, and there are no error messages in the execution logs.
I am attaching screenshots of my workflow for better clarity.
Has anyone encountered this issue before? Any suggestions on how to debug or fix this?
If you still need help with this, please share your workflow here.
Also, tell us your instance version and if it’s cloud of self-hosted.
