Code node (python)
n8n detected that some packages are missing. For more information, visit Troubleshooting | n8n Docs
n8n Task Broker ready on 127.0.0.1, port 5679
Failed to start Python task runner in internal mode. because Python 3 is missing from this system. Launching a Python runner in internal mode is intended only for debugging and is not recommended for production. Users are encouraged to deploy in external mode.
If you are in v2 , you need to set to external to run Python, since it uses Task-runner as default.
Check here:
