I want to split out items depending on key names matching values from the array ‘DateProperties’.
So if a key with a matching name occurs in the item, a ‘copy’ (with modifications) will be pushed to results.
My issue is that every item of ‘results’ is a copy of the last item that is pushed.
No error message, this is a pure JavaScript object referencing issue, that I can’t wrap my head around.
let result = [];
for (const item of $input.all()) {
for (const date of item.json.DateProperties) {
//check if null or empty
if (item.json[date] != null && item.json[date] != '') {
item.json.MasterCalendarDate = item.json[date]
item.json.hasDate = true;
item.json.tag = date;
result.push(item);
//console.log(result);
return result;
My current fix is below, but is there a way I could have made my previous attempt work?
let results = [];
let items = $input.all();
for(let i=0; i<items.length; i++){
for (const date of dates = items[i].json.DateProperties) {
if (items[i].json[date] != null && items[i].json[date] != '') {
results.push(
"json":
"MasterCalendarDate": items[i].json[date],
"hasDate": true,
"tag": date
"pairedItem": i
return results;
- n8n version:current
- Database (default: SQLite):default
- n8n EXECUTIONS_PROCESS setting (default: own, main):default
- Running n8n via (Docker, npm, n8n cloud, desktop app):docker
- Operating system:Ubuntu Server
