I am tryingt to improve my RAG results with a reranker. I do not think there is an appropriate node yet. Therefore I would like to implement it with a Langchain code node. I would want to do so using a Cohere reranker.
My question is regarding the correct steps to import the packages needed and if someone possibly has done this before?
Thanks in Advance
- n8n version:
- Database (default: SQLite):
- Operating system:
Hey Paul,
Great question. I’m pleased to say that the cohere libraries are available in n8n and you can use it the langchain code node like so:
(Example taken from: Cohere Rerank | 🦜️🔗 Langchain)
const { CohereRerank } = require("@langchain/cohere");
const cohereRerank = new CohereRerank({
apiKey: '...', // You'll have to hardcode your key here
model: "rerank-english-v2.0", // Default
To use it in the example from my other post on using Langchain code node, we can do:
[Deleted]
Hope this helps!
Edit: Sorry, that was a bad example!
@Paul_Bogemann I’ve created a new Tutorial here which I think will help - Build A Custom Q&A Chain using Cohere Rerank (Using Langchain Code Node)
Hi Jim!
Thank you very much for the elaborated answer! This is a great Tutorial with strong level of detail!
