"Connection Lost" warning
Hi
I have the warning “Connection Lost” when editing a workflow. Can’t find the save button anymore. However, is I click on “workflows” to go home I have the popup asking me to save and it is working properly.
I recently upgraded from beta to 1.3.1, is it a known bug ?
Cheers
  • n8n version: 1.3.1
  • Database (default: SQLite): SQlite
  • n8n EXECUTIONS_PROCESS setting (default: own, main): ?
  • Operating system: Ubuntu server
Hi @Valerian_Lebert :wave: Thanks for reporting this, and sorry you’re experiencing it :see_no_evil:
This is indeed something our engineering team is looking into - I’ll let them know you’re seeing it too, and be back with you as soon as I have an update.
@EmeraldHerald
Thanks for your answer
Are there any workaround ? Currently, to save my workflow I have to go back to the workflow list. Are you aware of any other trick to be able to save current workflow ?
HI @Valerian_Lebert :wave: I’m unfortunately not aware of any workaround on this one at the moment :see_no_evil: You’ll be sure to know when there’s an update around this, though!
Hi @EmeraldHerald
I realized that this issue is more criticat than I thought : I can’t create a new webhook trigger for example.
When clicking “listen for events” I have the error connection lost to the server. Impossible to initialize the webhook trigger
I could fix my issue thanks to this post
I had change my nginx conf for websocket support
    location / {
        proxy_http_version 1.1;
        proxy_set_header Upgrade $http_upgrade; # websocket support
        proxy_set_header Connection "Upgrade";  # websocket support
        proxy_set_header Host $host;
        chunked_transfer_encoding off;
        proxy_buffering off;
        proxy_cache off;
HI @Valerian_Lebert - so sorry that you were having such a critical issue, but thank you so much for posting your solution!
