Connection lost: You have a connection issue or the server is down. n8n should reconnect automatically once the issue is resolved
I am also experiencing the same issue and reverting to v. 1.78.1 makes the problem disappear.
I am using NGINX Proxy manager as a reverse proxy. Had to enable websocket support. Then it started working again - also with the latest version 1.80.x
It’s running now (with some up and down trials with grok on the sideline)
Here’s part of the yml:
services:
n8n:
container_name: n8n
image: n8nio/n8n:1.80.3
restart: always
environment:
- N8N_HOST=${N8N_HOST}
- N8N_PROTOCOL=${N8N_PROTOCOL}
- N8N_PORT=5678
- N8N_ENCRYPTION_KEY=${N8N_ENCRYPTION_KEY}
- N8N_PUSH_BACKEND=sse
- N8N_EXPRESS_TRUST_PROXY=true
- DB_TYPE=postgresdb
- DB_POSTGRESDB_PORT=5432
- DB_POSTGRESDB_HOST=n8n-postgres
- DB_POSTGRESDB_DATABASE=n8n
- DB_POSTGRESDB_USER=n8n
- DB_POSTGRESDB_PASSWORD=${POSTGRES_PASSWORD}
- WEBHOOK_URL= => my url
volumes:
- ./n8n/data:/home/node/.n8n
networks:
- n8n-network
n8n-postgres:
container_name: n8n-postgres
image: postgres:15
restart: always
environment:
- POSTGRES_DB=n8n
- POSTGRES_USER=n8n
- POSTGRES_PASSWORD=${POSTGRES_PASSWORD}
volumes:
- ./n8n/postgresql:/var/lib/postgresql/data
networks:
- n8n-network
nginx-proxy:
container_name: nginx-proxy
image: ‘jc21/nginx-proxy-manager:latest’
restart: always
ports:
- ‘80:80’
- ‘443:443’
- ‘81:81’
volumes:
- ./nginx/data:/data
- ./nginx/letsencrypt:/etc/letsencrypt
networks:
- n8n-network
Hi,
The same settings, particularly N8N_PUSH_BACKEND=sse works for me. Changing the value to websocket will result in the mentioned error.
Worked for me, current version 1.80.4, docker, reverse proxy (apache)
N8N_PUSH_BACKEND = sse
Thanks.
You must add N8N_PROXY_HOPS =1 (it’s the number of reverse-proxies n8n is running behind). You can suppress N8N_EXPRESS_TRUST_PROXY, i think.
Work to me. Thanks
Worked for me, current version 1.81.4, docker, reverse proxy (Nginx), Ubuntu 24.04
N8N_PUSH_BACKEND=websocket
If it still doesn’t work, adjust Nginx to use Websocks.
Edit your n8n’s Nginx configuration.
sudo nano /etc/nginx/sites-available/n8n
Add the following lines to /location
proxy_http_version 1.1; # Required for WebSocket
proxy_set_header Upgrade $http_upgrade; # Required for WebSocket
proxy_set_header Connection "upgrade"; # Required for WebSocket
Save and restart Nginx
sudo nginx -t
sudo systemctl restart nginx
It should work now!
where can i find the environment / configuration file in ./public_html/node_modules
to change setting ```
Hi where can i find the configuration file to change this setting?
Hi @Erik_Augustin,
If you use Docker, you can set this in your Docker compose file.
Its an npm install
You can refer to this link for more details, basically it’s just importing the file into the app.
Thanks this works for me
funcionou !
thanks man you saved my day :smiley:
I am experiencing this issue, but with cloud hosted n8n.
I tried updating to v1.84.1 this morning but the problem still remains.
My workflows started encountering this since Thursday the 20th of March 2025.
With 1.84.3, where I had a 404 for all nodes, I changed N8N_PUSH_BACKEND=sse back to websocket and restarted. Then I (obviously) I had a connection lost with the server. Then I changed it back to N8N_PUSH_BACKEND=sse (it’s a docker-compose installation with nginx on an Ubuntu 24.04 cloud server with a postgres db) and I restarted again and yes, the problem has gone. :grinning:
same problem, I have pinged my server support, will post back here if/when he fixes it.
This is the solution, i have the versión 1.85.4 and copy and paste, follow the steps and enjoy. tanks for your help!!
