Connection timeout help
is there a bug currently going on with the imap node? i checked my credential its correct, i trried multiple times it keeps giving me errors, then randomly it shows green connection or correct, when i hop into the workflow and test out the imap or the workflow it doesnt work gives me this error: connection timed out. timeout = 20000 ms .. whats going on? bug or something? i was working fine yesterday no issues. nothing changed i havent updated anything, except after the issue i thought updating n8n would fix it. help please
