Convert to Base64 and then SHA256
I’m working on an automation that I need to first convert a string to Base64 and then hash it with SHA256. I’ve searched the community and found some stuff, but the config is failing.
For the Base64 conversion, I used a manual Set which goes to a Code function. The code function runs the below:
$item.encoded_message = Buffer.from(item.message).toString(‘base64’);
return $item;
I get this error back:
The first argument must be of type string or an instance of Buffer, ArrayBuffer, or Array or an Array-like Object. Received undefined [line 1, for item 0]
TypeError
Once I get this working I need to hash it via SHA256 which I’m trying to figure out how to do still.
I’m using the Cloud version of N8N.
Sorry thought I mentioned this at the end:
  • n8n version: 1.44.1
  • Database (default: SQLite): Whatever comes with N8N Cloud
  • Running n8n via (Docker, npm, n8n cloud, desktop app): N8N Cloud
  • Operating system: N8N Cloud
Welcome to the community @AutomationFail !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
n8n has its own dedicated method to base64 encode strings, namely base64Encode().
Here’s a simple workflow to demonstrate this method as well hashing the message (using Crypto mode).
