Converting Nested array to string using keys
Hello there, is there a simple way to convert a nested array using a function or Set node? I’m trying to transform json like this:
	"allData": [{
			"counter": 2,
			"name": "Sample String 1"
			"counter": 2,
			"name": "Sample String 2"
	"update": {
		"count": 2
to this:
Sample String 1, Sample String 2
The example below should do it:
      "nodes": [
          "parameters": {},
          "name": "Start",
          "typeVersion": 1,
          "position": [
            250,
            300
          "parameters": {
            "functionCode": "return [\n  {\n    json: [{\n\t\"allData\": [{\n\t\t\t\"counter\": 2,\n\t\t\t\"name\": \"Sample String 1\"\n\t\t},\n\t\t{\n\t\t\t\"counter\": 2,\n\t\t\t\"name\": \"Sample String 2\"\n\t\t}\n\t],\n\t\"update\": {\n\t\t\"count\": 2\n\t}\n}]\n  }\n]\n"
          "name": "Function",
          "typeVersion": 1,
          "position": [
            540,
            300
          "notesInFlow": true,
          "notes": "Mockup data"
          "parameters": {
            "functionCode": "\nreturn [\n  {\n    json: {\n      names: items[0].json[0].allData.map((e) => e.name).join(',')\n    },\n  }\n]"
          "name": "Function1",
          "typeVersion": 1,
          "position": [
            750,
            300
          "notes": "Map data"
      "connections": {
        "Start": {
          "main": [
                "node": "Function",
                "type": "main",
                "index": 0
        "Function": {
          "main": [
                "node": "Function1",
                "type": "main",
                "index": 0
I’m getting an error when attempting to apply the example to my final project, but in the example I was able to replicate the reason for the error. The actual format of my data is:
return [
    json: {
	"allData": [{
			"counter": 2,
			"result": "Sample String 1"
			"counter": 2,
			"result": "Sample String 2"
And this is the example showing the error with the data being output in way my project outputs it:
  "nodes": [
      "parameters": {},
      "name": "Start",
      "typeVersion": 1,
      "position": [
        150,
        550
      "parameters": {
        "functionCode": "return [\n  {\n    json: {\n\t\"allData\": [{\n\t\t\t\"counter\": 2,\n\t\t\t\"result\": \"Sample String 1\"\n\t\t},\n\t\t{\n\t\t\t\"counter\": 2,\n\t\t\t\"result\": \"Sample String 2\"\n\t\t}\n\t]\n}\n  }\n]\n"
      "name": "Function",
      "typeVersion": 1,
      "position": [
        340,
        550
      "parameters": {
        "functionCode": "\nreturn [\n  {\n    json: {\n      names: items[0].json[0].allData.map((e) => e.result).join(',')\n    },\n  }\n]"
      "typeVersion": 1,
      "position": [
        550,
        550
      "notes": "Map data"
  "connections": {
    "Start": {
      "main": [
            "node": "Function",
            "type": "main",
            "index": 0
    "Function": {
      "main": [
            "type": "main",
            "index": 0
ahh yes, the example that I sent uses an array instead of an object. Anyways, the function node should look like this:
return [
    json: {
      names: items[0].json.allData.map((e) => e.name).join(',')
  "nodes": [
      "parameters": {},
      "name": "Start",
      "typeVersion": 1,
      "position": [
        -130,
        190
      "parameters": {
        "functionCode": "return [\n  {\n    json: {\n\t\"allData\": [{\n\t\t\t\"counter\": 2,\n\t\t\t\"name\": \"Sample String 1\"\n\t\t},\n\t\t{\n\t\t\t\"counter\": 2,\n\t\t\t\"name\": \"Sample String 2\"\n\t\t}\n\t],\n\t\"update\": {\n\t\t\"count\": 2\n\t}\n}\n  }\n]\n"
      "name": "Function",
      "typeVersion": 1,
      "position": [
        50,
        190
      "parameters": {
        "functionCode": "\nreturn [\n  {\n    json: {\n      names: items[0].json.allData.map((e) => e.name).join(',')\n    },\n  }\n]"
      "typeVersion": 1,
      "position": [
        260,
        190
      "notes": "Map data"
  "connections": {
    "Start": {
      "main": [
            "node": "Function",
            "type": "main",
            "index": 0
    "Function": {
      "main": [
            "type": "main",
            "index": 0
It works!!! Thank you so much! Do you happen to know any good resources for learning the javascript needed to write these functions myself? Regardless, thanks again!
Glad that it worked. The resources below should help you with that.
https://docs.n8n.io/reference/function-nodes.html#function-and-function-item-nodes
