Hello Everyone,
I was trying the Course level 2 work flow exercise. I did setup correctly the discord parameter and give correct message format. but unfortunately, I am getting following error “ Cannot read properties of undefined (reading ‘Error’) “
I tried deleting the discord configuration and recreated but still no luck.
I am using cloud version N8N version 1.109.1 (cloud)
Below is stack trace. I really appreciate your help.
“errorMessage”: “Cannot read properties of undefined (reading ‘error’)”,
“errorDetails”: {},
“n8nDetails”: {
“n8nVersion”: “1.109.1 (Cloud)”,
“stackTrace”: [
“TypeError: Cannot read properties of undefined (reading ‘error’)”,
" at ExecuteContext.parseDiscordError (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_1af219c3f47f2a1223ec4ccec249a974/node_modules/n8n-nodes-base/nodes/Discord/v2/helpers/utils.ts:32:30)“,
" at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_1af219c3f47f2a1223ec4ccec249a974/node_modules/n8n-nodes-base/nodes/Discord/v2/actions/webhook/sendLegacy.operation.ts:153:34)”,
" at processTicksAndRejections (node:internal/process/task_queues:105:5)“,
" at ExecuteContext.router (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_1af219c3f47f2a1223ec4ccec249a974/node_modules/n8n-nodes-base/nodes/Discord/v2/actions/router.ts:70:17)”,
" at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_1af219c3f47f2a1223ec4ccec249a974/node_modules/n8n-nodes-base/nodes/Discord/v2/DiscordV2.node.ts:33:10)“,
" at WorkflowExecute.executeNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_5aee33ef851c7de341eb325c6a25e0ff/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1253:8)”,
" at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_5aee33ef851c7de341eb325c6a25e0ff/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1427:11)“,
" at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_5aee33ef851c7de341eb325c6a25e0ff/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1727:27”,
" at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_5aee33ef851c7de341eb325c6a25e0ff/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:2303:11"
