Cannot read properties of undefined (reading ‘error’)
i’m having this error in Discord send message action node in level 2 course, after trying different things nothing works. what could be the problem, i’ve tried ai assistant all reccomendations.
Hi @tayyab
Without more details like your workflow, screenshots, it’s difficult to understand the issue or suggest a fix.
Could you share a bit more info to help troubleshoot?
Right now for simplicity i’m just trying to send a message on n8n discord server using webhook url that was provided by n8n academy.
Hi @tayyab
For the n8n Course Level 2, please follow this structure in the Message box:
I sent the file using email with the label ID order21 . My ID: <your Unique ID>
If this resolves your issue, please like
and mark the reply as the solution
, Thanks!
Thanks for help. One last thing can you tell me why simple msg is not working? like: “hello world”.
It’s probably to prevent spam and to make it easier for them to detect the correct message format in the n8n Discord course channel..
