Creator Portal - Automated Review stuck "in progress" for hours
Hi, I submitted my community node n8n-nodes-brasil-hub@0.1.6 to the Creator Portal a few hours ago. The Automated Review has been stuck on “in progress” since then — no email, no
status change.
The package passes @n8n/scan-community-package locally and has npm provenance + attestations. I can’t resubmit because the portal says “Package is already submitted for
verification.”
Could someone on the n8n team check if the review queue is stuck? Package: https://www.npmjs.com/package/n8n-nodes-brasil-hub
Thanks!
This is a known issue with the Creator Portal review queue getting stuck, youre not doing anything wrong. Id hop on the n8n Discord and post in the #community-nodes channel with your package details, that tends to get eyes on it faster than the forum. You can also email support@n8n.io directly.
This is usually a known issue. I suggest sending an email to nodes@n8n.io
