Creator portal - Node submission stuck on "Automated review in progress"
Hello,
I submitted a node for review in the creator portal a few weeks ago and since then it’s been stuck on “Automated review” with the status “In progress”. I cannot find any way to re-submit or re-trigger the node…
Here is a screenshot of what I get in the creator portal :
Has this ever happened to you ? If so, how to fix it ?
Thanks for your help :folded_hands:
Hasn’t happened to me, but I would contact support if its been doing that for a few weeks. There’s not much you can really do on your end. See if you got an email though if the checks were completed to see if it was a bug but I would contact support.
If this helps you feel free to mark my reply as a solution, but hopefully your problem gets solved!
