I think I found a critical bug with Split in Batches node.
Situation:
I was working with Data bases and Split in Batches node. If I use this node inside loop everything works fine. But I need to clear data before next loop so I turned Reset Option in Split in Batches node. And then my webpage got frozen and nothing helped except server rebooting.
My simplified workflow:
Also I’ve tried to expand RAM on my server from 4gb to 8gb but it didn’t help.
I need to know how to how to clear data in second Split in Batches node to get actual data and without server crashing?
