Debugging Javascript Code Tool running in docker: Where is Console.log going?
I am running n8n v1.75.2 using the docker image, on my own AWS server. I’ve been writing some AI Agent Code Tools in Javascript, and am running in to the need to debug some of the code. I tried using Console.log, but I can’t figure out where this is going?
I’m running the image using the command:
sudo docker run -it --rm --name n8n -p 5678:5678 -e N8N_SECURE_COOKIE=FALSE -e NODE_FUNCTION_ALLOW_EXTERNAL=node-fetch -v n8n_data:/home/node/.n8n docker.n8n.io/n8nio/n8n
I’m new to n8n, and have not customized much yet … I have tools working, but now have one throwing errors and I can’t see what is going wrong. :-/
No error message … I just can’t seem to find where Console.log output might be going, or if I have to set something else up?
  • n8n version: v1.75.2
  • Database (default: SQLite): SQLLite
  • Operating system: Amazon Linux
Welcome to the community @Humancell !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
You will find the logs in the browser Console.
