Discord node credentials problem
I’m setting up the discord node, everything seems right
in N8N
and in discord
But when I try to add the bot to the client server trough the generated URL I’ve got this
I’ve now tried with the BOT method, and the problem remain the same…
I’m totally noob about Discord stuff, which doesn’t help!
Version: 1.72.1
database: default
execution process: default
Running N8N on Hetzner cloud
Operating system: macOS
Version: 1.72.1
database: default
I have solved it, simply changing browser
in Arc problems, in Brave working, I don’t know why!
Hey @Alexandra_Spalato
Can you reset your secret as you have shared it in a screenshot and someone may now have access to it and could spoof your app.
Thanks , I’ve changed it now
