Hi there,
I have an issue with the Discord node setting. I’m following with the guideline on “Text Courses > Level Two > Automating a business workflow > Workflow 2”. Then it run with error.
Please help if someone know how to fix. Thank you.
The error details below copied from Discord node
“errorMessage”: “”,
“errorDetails”: {},
“n8nDetails”: {
“nodeName”: “Discord”,
“nodeType”: “n8n-nodes-base.discord”,
“nodeVersion”: 2,
“operation”: “sendLegacy”,
“itemIndex”: 0,
“time”: “12/2/2024, 11:26:45 AM”,
“n8nVersion”: “1.69.2 (Self Hosted)”,
“binaryDataMode”: “default”,
“stackTrace”: [
“NodeOperationError: “,
" at Object.parseDiscordError (/Users/pinyu/.nvm/versions/node/v20.18.1/lib/node_modules/n8n/node_modules/n8n-nodes-base/nodes/Discord/v2/helpers/utils.ts:80:9)”,
" at Object.execute (/Users/pinyu/.nvm/versions/node/v20.18.1/lib/node_modules/n8n/node_modules/n8n-nodes-base/nodes/Discord/v2/actions/webhook/sendLegacy.operation.ts:154:34)”,
" at processTicksAndRejections (node:internal/process/task_queues:95:5)“,
" at Object.router (/Users/pinyu/.nvm/versions/node/v20.18.1/lib/node_modules/n8n/node_modules/n8n-nodes-base/nodes/Discord/v2/actions/router.ts:61:17)”,
" at Object.execute (/Users/pinyu/.nvm/versions/node/v20.18.1/lib/node_modules/n8n/node_modules/n8n-nodes-base/nodes/Discord/v2/DiscordV2.node.ts:31:10)“,
" at Workflow.runNode (/Users/pinyu/.nvm/versions/node/v20.18.1/lib/node_modules/n8n/node_modules/n8n-workflow/src/Workflow.ts:1383:8)”,
" at /Users/pinyu/.nvm/versions/node/v20.18.1/lib/node_modules/n8n/node_modules/n8n-core/src/WorkflowExecute.ts:1162:27",
" at /Users/pinyu/.nvm/versions/node/v20.18.1/lib/node_modules/n8n/node_modules/n8n-core/src/WorkflowExecute.ts:1883:11"
