Hello,
I have already read the guide on how to add python3 to container at this link
However, doing so if I try to install the pandas library from pip3, it gives errors during the installation phase.
How can I add another base image to the container already built to support python3 and pandas?
An image taken for example from the docker hub:Docker Hub
Or how can I generally correctly install external libraries like pandas?
Great thank you very much.
It is very convenient to have the dockerfile.
I could simply replace ubuntu as the base image and install python and the various libraries I need.
I noticed that there is already a debian-based image on your dockerhub, I used that as the base image.
The debian version not being the latest, it installed python 3.5 which was not compatible with the libraries I need.
So I updated it with the following command
RUN sed -i ās / stretch / buster / gā /etc/apt/sources.list
(Even though he still installed me python version 3.7 and the latest)
Do you advise me to use the official version with debian from dockerhub, updating it as I did, or to use the docker file you linked to me and use the latest ubuntu LTS as a base image?
What can be the most stable solution?
