Dynamic_credentials
so basically i have made a slack bot, i want it to access all my coworkers’ emails and send mails on their behalf, but I am having trouble creating their credentials to which i have found some solutions but i read that their is no way to switch between credentials dynamically.
I’d really appreciate it if someone could help.
  • n8n version: 1.114.3
  • Running n8n via (Docker):
  • Operating system: linux
I explained the possible solution here:
https://www.reddit.com/r/n8n/comments/1nxe2a7/i_solved_the_multicredential_problem_without/
In short, you need to
  • first export and store N8 credential ids
  • Prepare a mini workflow with dynamic expression of slack credential
  • Run a subworkflow as JSON and pass other parameters (I e. message texts etc)
Yes, this is an extremely hacky way :slight_smile:
