Error when dragging over fields - Problem in node ‘HTTP Request‘ JSON parameter needs to be valid JSON
when I drag over my “text” field from the prior schema it breaks my work flow “problem in node “http request’ json parameter needs to be valid Json: Here is the Json request:
“model”: “wan/2-5-text-to-video”,
“callBackUrl”: “your-domain.com,
“input”: {
“prompt”: {{$json.content.parts[0].text}}, (this is where it breaks)
“duration”: “10”,
“aspect_ratio”: “16:9”,
“resolution”: “720p”,
“enable_prompt_expansion”: true
when I expand the prompt it shows the proper data but, when I execute it doesn’t work right. I did a test with just plain text and the api is all connected right. Please help thanks Geremy.
Hey @Geremy_D !
I think you have to use quotes “ around the expression.
“prompt”: “{{$json.content.parts[0].text}}”,
Cheers!
I had quotes and it still didn’t work.
Hey @Geremy_D,
I can see the error that intended request, input must be an object, not an array
please use this :
“callBackUrl”: “``https://your-domain.com/api/callback”``,
“input”: {
“prompt”: “={{ $json.content.parts[0].text }}”,
“duration”: “10”,
and let me know if this works for you.
it did not
Hey, use JSON.stringify() or the .toJsonString() method in your expressions.
I see in your text that there are quotes “ characters, and it will break down the json.
what would that look like exactly in the code sorry I’m not very technical. Thanks. Geremy
“prompt”: {{ JSON.stringify($json.content.parts[0].text) }}
Or
“prompt”: {{ $json.content.parts[0].text.toJsonString() }}
OR replace quotes chars in the string…
“prompt”: {{ JSON.stringify($json.content.parts[0].text.replace(/"/g, “'”)) }}
hmm this did not work = “prompt”: {{ JSON.stringify($json.content.parts[0].text) }}
and this one is saying bad syntex…
  "model": "wan/2-5-text-to-video",
  "callBackUrl": "https://your-domain.com/api/callback",
  "input": {
    "prompt": {{ JSON.stringify($json.content.parts[0].text) }},
    "duration": "10",
    "aspect_ratio": "16:9",
    "resolution": "720p",
    "enable_prompt_expansion": true
your the man! thank you sir this worked
