The idea is:
Introduce execution quota management to allow instance admins to allocate and enforce execution limits at the project and workflow level.
This would include:
- Per-project quotas: Allocate a monthly execution budget to each n8n project (e.g., “R&D” gets 5,000/month, “Finance” gets 3,000/month)
- Per-workflow quotas: Set a maximum number of executions per workflow over a given period (e.g., max 500/month or max 10/hour)
- Admin dashboard: View execution consumption broken down by project and workflow to identify top consumers
- Configurable actions when quota is reached: Pause the workflow, send a notification, or both
My use case:
We run a self-hosted n8n instance shared across multiple teams (R&D, Product, Finance, Legal, etc…). Depending on the license plan, we have a finite number of executions per month.
Today there is no way to prevent a single misconfigured workflow from consuming the entire monthly quota. A schedule trigger set too aggressively or a webhook receiving unexpected traffic can burn through thousands of executions in hours, impacting all other teams.
We need to:
- Control costs - prevent unexpected overages that affect billing or force an unplanned license upgrade
- Protect against runaway workflows - a single workflow shouldn’t be able to exhaust the instance quota
- Ensure fair sharing across teams - allocate execution budgets per project so each team has a guaranteed allocation
- Multi-team instances are common - as n8n adoption grows within organizations, shared instances become the norm. Without quotas, there’s no governance
- No workaround exists - maintainers confirmed there is no built-in way to limit executions (How to limit number of executions per workflow). Building custom rate limiting per workflow is fragile and doesn’t solve the project-level allocation problem
- Execution limits already exist at the plan level - the infrastructure for counting executions is already there. Extending it to project/workflow granularity is a natural evolution
- Other platforms offer this - quota management is a standard feature in enterprise automation platforms
- How to limit number of executions per workflow - confirmed not possible
- Workflow Limitation per user [Self hosted] - closed unresolved
- Workflows executions monthly limit - users asking about limits
- Clarification on Execution Limits: Is it per execution or per node?
Yes, I’m willing to contribute code to implement this feature if it can speed up the implementation. Happy to submit a PR once the approach is validated by the maintainers. ![]()
