ERROR: Can’t get data for expression under ‘JSON’ field
In node ‘undefined’, output item 0 points to an input item on node ‘IF4‘ that doesn’t exist.
I don’t know why data is not pulling from previous nodes and I keeping getting this error.
Never happened before as long as I am redirecting the true or false.
Very weird
Hi @Keep_Innovations - can you fill out the following template, and also provide a sample workflow where we can see this in action? Ideally this would be a workflow that wouldn’t require any outside credentials
- n8n version:
- Database (default: SQLite):
- Operating system:
Its now working…not sure why it started doing that.
No worries, @Keep_Innovations - if you have it happen again, just provide us an example we can look into.
