Extract values from string
Hi,
Trying to mix this Break multiple values in JSON with this Splitting an array to extract values
I got in a JSON:
“site”:“https://www.domain1.com/”,
“site”:“https://domain2.com/”,
“site”:“http://www.1.domain.com/”,
How to get to:
“site”:“domain1.com”,
“site”:“domain2.com”,
“site”:“1.domain.com”,
I assume I need some iterations? To get rid of "http(s) prefix and the “www” and “/” but so far I could only get specific defined strings out of it. Thank you very much once again :slight_smile:. Have a great weekend.
The example below should do it.
  "nodes": [
      "parameters": {},
      "name": "Start",
      "typeVersion": 1,
      "position": [
        250,
        300
      "parameters": {
        "functionCode": "return [\n  {\n    json: {\n      domain: 'https://www.domain1.com/',\n    }\n  },\n    {\n    json: {\n      domain: 'https://www.domain2.com/',\n    }\n  },\n    {\n    json: {\n      domain: 'https://www.domain3.com/',\n    }\n  }\n]"
      "name": "Function",
      "typeVersion": 1,
      "position": [
        460,
        300
      "parameters": {
        "functionCode": "\nconst matches = item.domain.match(/^https?\\:\\/\\/([^\\/?#]+)(?:[\\/?#]|$)/i);\n  // extract hostname (will be null if no match is found)\nitem._domain = matches && matches[1];\n\nitem._domain = item._domain.replace('www.', '');\nreturn item"
      "name": "FunctionItem",
      "type": "n8n-nodes-base.functionItem",
      "typeVersion": 1,
      "position": [
        700,
        300
  "connections": {
    "Start": {
      "main": [
            "node": "Function",
            "type": "main",
            "index": 0
    "Function": {
      "main": [
            "node": "FunctionItem",
            "type": "main",
            "index": 0
Wow, jeez guys, you are the best, fast and this worked perfect once more :slight_smile:.
Thanks a mil
