Not sure how I can describe it better. Above I show a picture with the node with data however it works regardless, the difference is clicking EXECUTE NODE vs EXECUTE WORKFLOW.
I am aware the file has nothing to do with it and I never said that, I merely said I found generic functions where the way the date was being handled was by creating a new date then formatting it so I simply followed that process.
When I click EXECUTE on node whether there is data or no data it works, click on EXECUTE workflow it doesn’t work, can’t explicitly even sent toString the only fix I have found is essentially to CREATE a new date and then force it to ISO like this:
This is still a bug, if the data coming in is a string, and even forcing it to string not sure why n8n is manipulating data without the user requesting it, it only happens on date fields
