Frequent Postgres Connection Failures in n8n (TLS handshake, DNS EAI_AGAIN, timeouts) with AWS RDS
Hi n8n community :waving_hand:,
I’m facing frequent and intermittent PostgreSQL connection failures in my self-hosted n8n setup, and I’m trying to understand whether this is an n8n issue, Node.js behavior, or something related to AWS RDS networking/DNS.
I’ve self-hosted n8n in Vultr VM . n8n’s own db is postgres db that is hosted inside docker.
In my workflows , I’m connecting to external postgres DBs using the postgres db nodes of n8n.
Observed Errors (intermittent)
The same simple queries fail randomly at random times :
:one: TLS handshake failure
Client network socket disconnected before secure TLS connection was established
:two: DNS resolution failure
getaddrinfo EAI_AGAIN datacurve-crawling-database.cs9o80ocag8d.us-east-1.rds.amazonaws.com
The DNS server returned an error, perhaps the server is offline
:three: Connection timeout
Connection timed out
100.31.27.197:5432
What I’ve Checked
Query complexity: :cross_mark: Not an issue (simple COUNT queries)
n8n workflow logic: :cross_mark: Not the issue (fails at connection level)
This is impacting scheduled workflows, and I’m trying to determine whether:
This is an n8n Postgres node issue
A Node.js DNS/TLS issue
Or an AWS RDS networking edge case
Thanks in advance!
hello @gaurav.pant
Seems you have a network issue on the n8n instance. DNS and TLS are mostly affected by the host; n8n is just a consumer.
so , the problem is with my AWS database ?
n8n should work ?
not the database, the host instance of the n8n (where it resides). in AWS usually it’s an EC2 instance.
