Hi guys,
this is my first post here and first of all, n8n looks amazing. I think it is an incredible tool.
Also I love the idea of fair-code (never heard it before) and I hope to give something back to the community and to the project.
I made a fresh server installation on ubuntu20.04 with docker. Everything looks good at installation.
But when I try open the page it gives me a 404 error.
What am I doing wrong?
SSL works and everything seems to be fine.
Is there a n8n log somewhere?
As @Benedikt_Bohm pointed out is it a good start to make sure that the container is running. If it is you can get it output via docker logs <container-name> for example docker logs n8n
Did you follow our server-setup guide?
If so I did do exactly the same a few weeks ago also on ubuntu 20.04 and for me, it worked fine. So would then check if the domain and subdomain are set correctly.
thanks for the answers guys.
This is what is in the logs for the second container (n8n):
UserSettings got generated and saved to: /home/node/.n8n/config
(node:6) UnhandledPromiseRejectionWarning: Error: There was an error: EACCES: permission denied, open '/home/node/.n8n/config'
at Object.error (/usr/local/lib/node_modules/n8n/node_modules/@oclif/errors/lib/index.js:26:15)
at Start.error (/usr/local/lib/node_modules/n8n/node_modules/@oclif/command/lib/command.js:60:23)
at /usr/local/lib/node_modules/n8n/dist/commands/start.js:134:22
(node:6) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
(node:6) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
(node:6) UnhandledPromiseRejectionWarning: Error: SQLITE_CANTOPEN: unable to open database file
(node:6) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
So there is a problem with the read/write permissions. But I followed the tutorial exactly (at least i think so…)
@Stephano_Fernandes do you get an error in the docker logs? Are you also able to share the environment options you are running (removing anything important)
Hi.. Checking the erros logs, it seems to me some erro ir the ports of traefik container. Please see attached. Please let me any other command that I can run to share more info with you. I am a begginer. Thank you !
That could be the one, Looks like something is unhappy do you have something already listening on port 80 and 443?
I am not sure how Traefik actually works but it does seem to be unhappy. Are you running on this a webserver that already has something like Apache / IIS or Nginx running?
I am running on a server on Digital Ocean. How can I check if there is something already running on ports 80 and 443? I just set up this new server yesterday on Digital Ocean, it is a brand new Ubuntu 20.10 x64 machine and the only packages I installed are the ones listed in the tutorial to set the server.
