From Instagram post to Wordpress article
Hi fam,
I have a community on Instagram posting each day about 2 to 3 post image, which I plan before via buffer in the evening. 1 post contains approximately 8 to 10 Max image.
The first image is suitable for the presentation title with an image in the background illustrating the title.
The other image of the post are just text put on a black background
I say that for the basic context.
And I would therefore like to automate later, these posts do on Instagram, in article on WordPress.
So it would be necessary:
  • Analyze each post image
  • Extract the different texts
  • put them in an AI by giving it some quick (which I have already done)
  • Then say later to create an article on WordPress for my online blog
I tried to create this on a workflow, but no online tutorial says as he does to do this step, and I have the impression of having done something in everything I have risen.
Or to the clearest, how to do it?
I have question, before you add them all into buffer, where do you do your post? And what is the process?
Is it Ai generated?
Is it manual?
Thanks!
