A few months ago, I was building an automation for a client and thought:
“Could I just tell AI what I want… and get a working workflow?”
I tried every AI option I could find.
Unfortunately I ended up with mostly broken workflos. Wrong nodes. Missing connections.
It felt like AI was still years away from building something I could actually use.
So I built 8nodes… a multi-agent AI Workflow IDE for n8n that can:
Import your existing workflows
Generate workflows from plain English descriptions
Turn an image into a working workflow
Let you edit workflows in chat (like Cursor, but for n8n)
You can Try it here 8nodes.dev
It’s a multi-agent system with:
An Architect that plans the flow
A Node Designer that picks the perfect n8n nodes
A Wiring Engineer who connects everything
A QA Agent that tests it end-to-end
You get a complete, runnable workflow you can export straight to n8n with clear names, connections, and parameters already filled in… then all you have to do is add credentials for some nodes and it’s good to go
Because it’s kinda like Cursor, you can preview, tweak, or ask for changes in plain English, and edits apply instantly with layout controls and safety checks.
It’s like having a senior automation team that never sleeps
Why I’m confident in it
I’ve tested 8nodes against the best models out there and shared the results:
Full comparison: 8nodes vs frontier models
More recently: 8nodes + GPT-5 vs GPT-5 alone
I’ve used it for client work. Receive messages from people sharing how they literally saved hours with this.. Because 8nodes hands you a finished, working machine.
Now, I need your help to break it
I want you to push this thing to the edge.
Please Try your wildest “there’s no way this will work” ideas
Share every magic moment and every hiccup
Feel free to send use cases, feature ideas, and weird edge cases
The goal is to find its limits and smash through them.
I’m super easy to reach, hanging out in the Discord (link on the site) and please feel free to send me a X/Twitter DM (https://x.com/richardsondx)
What’s Next
I’m working on a companion Chrome extension to make it an even better integration to n8n so that you can see your workflow directly generated there. Not sure when I’ll release this but this is on the work
I also want to make this a powerhouse at generating clusters nodes and sub workflow as wells. I’m very close with this and been documenting my progress on X/Twitter.
Happy automating
Richardson
