Generate PDFs in n8n with DocuGenerate
Hi everyone,
DocuGenerate is a document generation API that turns Word templates into clean PDFs. You design a template with merge tags, pass your data as JSON, and get back a finished document. The DocuGenerate node for n8n is available, and we wanted to introduce it here.
n8n-integration-demo
Getting started
  • On n8n Cloud, search for DocuGenerate when adding a node and click Install node.
  • On self-hosted n8n, install it as a community node from Settings > Community nodes using the package n8n-nodes-docugenerate.
  • The first time you use an action, you’ll be prompted for a credential. Paste your DocuGenerate API key and you’re set.
What you can do
  • Generate document is the main action. Pick a template, choose the output format (PDF, Word, and others), and pass your data. The Data field defaults to {{ $json }}, so it uses the previous node’s output automatically, or you can map fields manually.
  • Manage your account with actions like List templates, Get template, List documents, Get document, Update document, and the matching Delete actions.
Links
Happy to answer any questions here, and we’d love to hear what you build.
