You are showing two totally different credential types. The above one is of type “GetResponse OAuth2” and the one bellow from the generic type “OAuth2”.
The first one you should get displayed if you create credentials from the GetResponse-Node, the one bellow if you use the HTTP Request-Node.
Hello @jan: I know. But I need to connect with Getresponse with HTTP Request node because Getresponse node only offers contact operations. I’d like to pull somehow reports.
And edit: for testing purposes - I can’t get the GetResponse OAuth2 to work either: it says ‘updated’, but does not redirect to getresponse to authorize (I’m using a ngrok tunnel on localhost).
Thanks Jan. This helps a bit, I think I need to investigate further. The problem is probably in api endpoints and authorization urls, because I’m using a polish enterprise getresponse edition and it has everything setup differently…
Jan,
I think I’ve found the issue. Figured out correct endpoints, but I need to pass additional parameter (X-domain with value) in header when authorizing. Is there a way to do it? I can add a header parameter in HTTP request, but cannot (or don’t know how to) do it when authorizing. Can you please help with this?
Edit: and it turns out, that when n8n gets an error respose when oauth2 authorizing - it crashes.
