Github PR review timeline - N8N Sharepoint node
I’ve submitted a PR that enhances the SharePoint node by allowing users to select document libraries other than the default “Documents” library. I tested this thoroughly on my local n8n instance and confirmed that it works as expected.
What is the expected timeline for reviewing and merging this PR into a release? This limitation in the SharePoint node is a significant blocker for many enterprise and security‑conscious use cases, where organisations often configure additional document libraries with distinct IAM settings rather than relying solely on the default Documents library.
Would i be better off creating a separate community node and instruct my enterprise users to use that instead of the core n8n SharePoint node?
wow…. community node it is…
