Gmail node 'send and wait for approval' not works
hi, the problem is that when i answer/approve the email sent from gmail node the cycle restart without any reason.
the workflow restart all the time
Kooha-2025-02-07-23-44-04
i share a quick video
n8n Version: 1.77.3
database: postgres
n8n EXECUTIONS_PROCESS setting: default
running: docker compose
os: linux alpine
Hi,
I have the same problem.
My Workflow
(It’s not finished, but 1st steps don’t work as attended)
I Receive some information and I need to analyze a text and send a mail for approval.
I tried with Gmail and Outlook. I have the same arror.
Error : When I click on approval, the workflow restart. So it’s an infinite loop.
Thanks
n8n Version: 1.77.3
database: postgres
n8n EXECUTIONS_MODE setting: queue - 2 workers
running: docker swarm (10 nodes)
os: linux debian arm64v8
Same here. Any ideas?
Hey, this issue looks like it might be fixed in 1.79.0, as part of this PR. Do you want to try updating and seeing if this resolves it?
Let me try NOW! :slight_smile:
It worked man!!! Thanks a lot!
It works for me too.
Thanks a lot :slight_smile:
