Help me to build a invoice extractor
Hello everybody,
I wanted to create a invoice processing tool through n8n. My process will be
  1. Upload invoice from google drive
  2. File Conversion from Excel
  3. Invoice process as my desired data like Purchase Order, Price, product name, model, Manufacturer etc.
  4. Output the information in google sheet.
But I am not allowed to use any LLM model.
How could I build this properly?
TIA.
Google Drive node: Download the invoice file.
Extract from file node: Read and parse the Excel file.
Set/Function node: Map and process the required fields.
Google Sheets node: Append the processed data to your sheet.
This I think will go with CSV or excelโ€ฆ but for advanced parsing like PDF, nothing on my mind yetโ€ฆ
Adding to what Parintele_Damaskin said, for PDF parsing and stuff, you can try CustomJS PDF generator node
A practical n8n path is: download PDF โ†’ extract/OCR โ†’ normalize line items โ†’ append to CSV or Sheets. The key is to split header fields from table rows and keep a manual review branch for low-confidence files, because invoice tables are where automations usually break.
