Help setting up
I came across this service, it seems exactly like what I need but Im not tech. Do you offer support with initial set up?
There is no official support from n8n for setup as far as I know. But when you’re using the cloud service, there is no need to setup the n8n instance manually. If you want to run self-hosted n8n, consult the official docs: n8n Hosting Documentation and Guides | n8n Docs
To learn the basics on how to use n8n, you can do the following official courses: Text courses | n8n Docs
If you’re looking for a one-on-one consulting session and assistance for the self-hosted setup, let me know!
