Hi,
How do I convert thru expression?
from
[Object: {“filename”:“SDU.DAT”}]
to
{“receipts”: {“filename”: “SDU.DAT”}}
Hi,
from
to
Can you share the expression you are currently using? What you showed us it’s what the expression is resolving to.
{{$node[“Function”].json[“receipts”]}}
You can do: {{ { “receipts”: $node[“Function”].json[“receipts”] } }}
"nodes": [
"parameters": {},
"name": "Start",
"typeVersion": 1,
"position": [
250,
300
"parameters": {
"requestMethod": "POST",
"url": "https://webhook.site/0054b04d-2ae2-4461-805d-4d2800b6f51e",
"jsonParameters": true,
"options": {},
"bodyParametersJson": "={{ { \"receipts\": $node[\"Function\"].json[\"receipts\"] } }}"
"name": "HTTP Request",
"typeVersion": 1,
"position": [
740,
300
"parameters": {
"functionCode": "return [\n {\n json: {\n receipts: {\n name: 'aaaa`'\n }\n }\n }\n]"
"name": "Function",
"typeVersion": 1,
"position": [
460,
300
"connections": {
"Start": {
"main": [
"node": "Function",
"type": "main",
"index": 0
"Function": {
"main": [
"node": "HTTP Request",
"type": "main",
"index": 0
Hi Ricardo,
Even with this solution I am getting the following result to be passed to the next node.
[Object: {“receipts”:{“name”:“aaaa`”}}]
What I need is without Object i.e. {“receipts”:{“name”:“aaaa`”}}
Do not worry about that. It’s just the expression editor telling you that is resolving to an object. But that it’s not being passed.
Problem is I am calling flask API with result of expression, its not able to recognize JSON input, It is working if I manually remove and send static input. Anyway we can send plain text without [Object in there?
Are you using the HTTP node? if so can you show me how you are using it?
BodyContentType as JSON, JSON/Raw is checked, POST call, sending expression result as Body parameter
In the example that I sent you above, I did exactly that. Just run it and go here to see the request.
Added the workflow again below.
"nodes": [
"parameters": {},
"name": "Start",
"typeVersion": 1,
"position": [
250,
300
"parameters": {
"options": {},
"typeVersion": 1,
"position": [
800,
300
"parameters": {
"name": "Function",
"typeVersion": 1,
"position": [
520,
300
"connections": {
"Start": {
"main": [
"node": "Function",
"type": "main",
"index": 0
"Function": {
"main": [
"type": "main",
"index": 0
Thank you so much Ricardo, appreciate your patience. Its working now. I had to change program slightly, now it works with the way you sent.
Glad that it worked. Have fun.
