Help with gpt generated code
Hello, so I’m a total newbie to automation and I rely heavily on Gemini or GPT for coding guidance. Here’s my goal: I’m getting opportunities from pipelines via an HTTPS request (previous node) and I need to count them by status for a weekly tally. Can someone break down this GPT-generated code for me or offer some tips to simplify the process? Thanks a ton!
Oh I see, yeaah I thought the input.first part is important, I guess not :sweat_smile:. Thank you so much I’ll try it! But is there another thing I need to map or is the code above the only thing needed? But Thank you very much for this!
