I need help 😫
Please I need help with my workflow
Hello, what kind of issue are you currently facing, kindly be specific
API key refusing to work alongside http
Use HTTPS, not HTTPthis API key won’t work otherwise..if this help kindly mark resolved
could you kindly share what you are looking to get help with.
You can reach me at akinloluabdulmuqeet2001 [at] gmail [dot] com and I’ll point you in the right direction.
Hi I appreciate you reaching out I have already gotten it fixed
Thanks Michael..I got it sorted out i appreciate the help…it really helps :+1:
