Hi,
After launching N8N, as soon as I click the “Create Workflow” button, it says “Connection lost” and doesn’t resolve. My n8n version: “1.114.4”.
Could you help me?
Thanks…
I do this setup, works fine.
Thank you RIL. Could you tell me how you did it?
This might be useful for some people. The problem was solved when I opened it with Chrome instead of Safari.
use the built in n8n package in coolify, makes it easy - if you do custom domain that might be source of issue.
